Ansicht von 1 Antwort-Thread
Schlagwörter: print button editor
Hello All,
in the past, with OTRS, we needed to add a „Print“ button to the CDEditor and it was done like this:
However we have no clue how to do this in OTOBO, since the structe of files is different.
Please if anyone could push me in the right direction.
Kind Regards,
Marek
Ok, I have found a solution, you need to edit:
/otobo/Kernel/Output/HTML/Layout.pm
At the bottom there are CKEditor toolbar format templates.
