Ansicht von 1 Antwort-Thread
Hello to all,
I have a small problem with the addition of attachments on the version of otobo 10.0.10.
When I put 2 attachments on an article, I have only one attachment added.
Have you already had this problem?
Thank you in advance for your feedback,
Sincerely,
Mehdi ABDE
Hi Mehdi,
please check whether the SysConfig setting „HttpType“ matches your actual http type used. We encountered this once now, where https (the default) was set, but http was used. In this case the cookie cannot be used to store your login data and at some places errors are encountered.
Best regards, Sven
