    • #11932
        Good Evening,
        I have set auto closed ticket state but it doesn’t work fine.
        I have set date pending auto close ticket date today nine o’clock.
        The ticket result now in pending auto closed state.
        How can I correct this problem?
        Thank You
      • #11936
        Renée Bäcker
          Check the daemon
          perl bin/otobo.Console.pl Maint::Daemon::Summary
        • #11937
            Good Morning,
            I have check in otobo.Console.pl but I don’t see Maint::Daemon::Summary…:-(
            use strict;
            use warnings;
            use File::Basename;
            use FindBin qw($RealBin);
            use lib dirname($RealBin);
            use lib dirname($RealBin) . ‚/Kernel/cpan-lib‘;
            use lib dirname($RealBin) . ‚/Custom‘;
            use Kernel::System::ObjectManager;
            local $Kernel::OM = Kernel::System::ObjectManager->new(
            ‚Kernel::System::Log‘ => {
            LogPrefix => ‚OTOBO-otobo.Console.pl‘,
            exit $Kernel::OM->Get(‚Kernel::System::Console::InterfaceConsole‘)->Run(@ARGV);
            What can I check to resolve the error?
            Thank You
          • #11939
              I have find those errors..
              an’t locate DateTime.pm in @INC (you may need to install the DateTime module) (@INC contains: /var/lib/docker/volumes/otobo_opt_otobo/_data/Custom /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/cpan-lib /var/lib/docker/volumes/otobo_opt_otobo/_data /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.28.1 /usr/local/share/perl/5.28.1 /usr/lib/x86_64-linux-gnu/perl5/5.28 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.28 /usr/share/perl/5.28 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/System/DateTime.pm line 38.
              BEGIN failed–compilation aborted at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/System/DateTime.pm line 38.
              Compilation failed in require at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/Language.pm line 28.
              BEGIN failed–compilation aborted at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/Language.pm line 28.
              Compilation failed in require at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/Output/HTML/Layout.pm line 31.
              BEGIN failed–compilation aborted at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/Output/HTML/Layout.pm line 31.
              Compilation failed in require at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/System/ObjectManager.pm line 38.
              BEGIN failed–compilation aborted at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/System/ObjectManager.pm line 38.
              Compilation failed in require at otobo.Console.pl line 27.
              BEGIN failed–compilation aborted at otobo.Console.pl line 27.
            • #11944
                Infact if I try launch this command:
                perl /var/lib/docker/volumes/otobo_opt_otobo/_data/bin/otobo.CheckModules.pl -list
                The DateTime Module isn’t installed.
                I have followed installing with docker guide and in that guide there insn’t this part:
                Step 2: Install Additional Programs and Perl Modules
                Use the following script to get an overview of all installed and required CPAN modules and other external dependencies.
                root> perl /opt/otobo/bin/otobo.CheckModules.pl -list
                Checking for Perl Modules:
                o Archive::Tar…………………ok (v1.90)
                o Archive::Zip…………………ok (v1.37)
                o Crypt::Eksblowfish::Bcrypt…….ok (v0.009)
                Note
                Please note that OTOBO requires a working Perl installation with all core modules such as the module version. These modules are not explicitly checked by the script. You may need to install a perl-core package on some systems like RHEL that do not install the Perl core packages by default.
                To install the required and optional packages, you can use either CPAN or the package manager of your Linux distribution.
                Execute this command to get an install command to install the missing dependencies:
                root> /opt/otobo/bin/otobo.CheckModules.pl -inst
                Note
                There are a number of optional or alternative modules which can be installed, mostly for more customized versions of OTOBO. Calling CheckModules.pl without any argument will list its full functionality.
                I have tryed to install all modules following OTOBO installation guide but now I have this problem:
                ERROR: Can’t read /opt/otobo/RELEASE: No such file or directory This file is needed by central system parts of OTOBO, the system will not work without this file.
                Died at /var/lib/docker/volumes/otobo_opt_otobo/_data/Kernel/Config/Defaults.pm line 2068.
                How can I resolve this problem?
                Thank You
              • #11947
                  Hi Giordane,
                  this Docker stuff is indeed initially confusing, but after a while things are starting to make sense.
                  First, die check of the Modules is deliberately not mentioned in the installation instructions for Docker. This is because the required modules are already included in the Docker image. See https://github.com/RotherOSS/otobo/blob/rel-10_0/cpanfile.docker for the list of modules that are installed when an image is created.
                  Calling perl /var/lib/docker/volumes/otobo_opt_otobo/_data/bin/otobo.CheckModules.pl -list  on the Docker host does not make sense. The script is indeed the correct file, but for using it you need to be in the Docker container. This is briefly mentioned in the second Note in https://doc.otobo.org/manual/installation/stable/en/content/installation-docker.html#install-and-start-otobo . Out of curiosity I tried it myself.
                  bes:~/devel/OTOBO/otobo-docker (rel-10_0)$ docker exec -it otobo_web_1 bash
                  otobo@a22efab06266:~$ bin/otobo.CheckModules.pl –list | head
                  Required packages:
                  o Archive::Tar…………………ok (v2.36)
                  o Archive::Zip…………………ok (v1.68)
                  o Date::Format…………………ok (v2.24)
                  o DateTime…………………….ok (v1.54)
                  o DateTime::TimeZone………….ok (v2.47)
                  o Convert::BinHex………………ok (v1.125)
                  o DBI…………………………ok (v1.643)
                  o Digest::SHA………………….ok (v6.02)
                  otobo@a22efab06266:~$ bin/otobo.Console.pl Maint::Daemon::Summary
                  Gathering summary for all daemons…
                  System configuration sync:
                  Daemon is active.
                  Done.
                  I hope that helps,
                • #11961
                    Thank You Bes for your reply.
                    I’m newbie whith docker compose.
                    Can I ask you other question?
                    I’d like make default page as customer page but I don’t find nginx configuration file.
                    Where Can I find it? How Can I modify it for make customer page as default?
                    Is there a variable in otobo that permit it?
                    Thank You
