6. April 2023 um 16:41 Uhr - Views: 1025 #15038
I am trying to create some custom reports based on information in Otobo.
We are using the CMDB functionality, and now I am trying to create a report with a 3rd party reporting tool.In the configitem and configitem_history tables I do see some of the information, but just a bare minimum.
Not even close to what we have stored in CMDB.Where would I have to look to get the rest of the information?
Hopefully someone can point me in the right direction :)
Thank you
7. April 2023 um 15:23 Uhr #15040
okay, I found out that it is in the xml_storage table.
I managed to make it work using the following views:
CREATE VIEW vw_cmdb_users
AS
SELECT distinct CONCAT(UCASE(LEFT(b.xml_content_value, 3)), LCASE(SUBSTRING(b.xml_content_value, 4))) as username
FROM otobo.configitem a
left join otobo.xml_storage b on a.last_version_id = b.xml_key
where b.xml_type =’ITSM::ConfigItem::22′ and b.xml_content_key like ‚%owner%‘ and (xml_content_value not like ‚%{%}%‘ and length(xml_content_value) > 1)CREATE VIEW vw_assets_per_user
as
SELECT a.configitem_number,
c.username
inner join vw_cmdb_users c on lower(b.xml_content_value) = lower(c.username)
where b.xml_type =’ITSM::ConfigItem::22′ and length(b.xml_content_value) > 1CREATE VIEW vw_configitem_details
as
replace(Replace(Replace(Replace(Replace(Replace(Replace(Replace(Replace(Replace(Replace(replace(replace(replace(b.xml_content_key,’\“,“),'[1]{Version}[1]{‚,“),‘}[1]{Content}‘,“),’9′,“),’8′,“),’7′,“),’6′,“),’5′,“),’4′,“),’3′,“),’2′,“),’1′,“),’0′,“),‘}[]{‚,‘ ‚) as hw_type,
b.xml_content_value as ‚hw_detail‘
where b.xml_type =’ITSM::ConfigItem::22′ and b.xml_content_value not like ‚%{%}%‘ and length(b.xml_content_value) > 1 and xml_content_key not like ‚%TagKey%‘This might help someone else who is trying to query this information.
