    • #15409
      Andy Mohan
        We are witnessing entries in the system log as follows:
        CommunicationLog(ID:xxxxxx,AccountType:-,AccountID:-,Direction:Outgoing,Transport:Email,ObjectLogType:Message,ObjectLogID:yyyyyy)::Kernel::System::Email::SMTP => Envelope to ‚root@localhost‘ not accepted by the server: 501, 5.1.4 Recipient address reserved by RFC 2606
        Can anyone advise how I can suppress these ?
        Thanks in advance
        Andz
      • #15410
          Hi Andz,
          we have changed the mailadress for the Agent „root@localhost“ to a valid adress.
          Then in the system configuration search all entries with „root@localhost“ and change it to a valid email adress.
          You can read also the Post in the Znuny Forum: https://community.znuny.org/viewtopic.php?t=43265&p=175580
          I hope this helps you
          KR,
        • #15413
            just search in the System Configuration for „root@localhost“ and replace the mail address in these settings to a valid one.
            Cheers
