8. Februar 2022 um 10:22 Uhr - Views: 679 #12625
Hello! I’m using web service as requester. So i need to map inner fields in outgoing data for my external app. For example
Outgoing data before mapping:
'field1' => {
'innerField1' => 'val1',
'innerField2' => 'val2'
}Outgoing data after mapping:
'newField1' => {
'newInnerField1' => 'val1',
'newInnerField2' => 'val2'
}Can i do it using standart mapping interface in web services or by another way?
Thank you!
8. Februar 2022 um 12:23 Uhr #12628
You need to use XSLT for that:
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output method="xml" encoding="utf-8" indent="yes"/>
<xsl:template match="@*|node()">
<xsl:copy>
<xsl:apply-templates select="@*|node()"/>
</xsl:copy>
</xsl:template>
<xsl:template match="//field1">
<xsl:element name="newField1">
</xsl:element>
</xsl:template>
<xsl:template match="//field1/innerField1">
<newInnerField1>
<xsl:value-of select="//field1/innerField1" />
</newInnerField1>
</xsl:template>
<xsl:template match="//field1/innerField2">
<newInnerField2>
<xsl:value-of select="//field1/innerField2" />
</newInnerField2>
</xsl:template>
</xsl:stylesheet>
- Das Thema „ Inner fields mapping in web service“ ist für neue Antworten geschlossen.
