7. Mai 2021 um 2:59 Uhr - Views: 1346 #11473
I’m trying to configure my Otobo instance running on CentOS 8 with Apache and this server is behind a nginx as reverse proxy and SSL certificates.
The FQDN to agent portal is https://servicedesk.mydomain.com and the FQDN to customer portal is https://support.mydomain.com.
I configured the nginx and apache using similar OTRS config, but when I try to login on agent portal, after clicking on login, the page is refreshed, and login form is cleared.
Looking on Developer tools on browser, I found this message:
Unchecked runtime. lastError: Could not establish connection. Receiving end does not exist. index.pl:1
This is my Apache config (zzz_otobo.conf)
# Copyright (C) 2019-2021 Rother OSS GmbH, https://otobo.io/
# added for OTOBO (http://otobo.de/)
# --ServerAdmin webmaster@mydomain.com
ServerName servicedesk.mydomain.com
Alias /otobo-web/ „/opt/otobo/var/httpd/htdocs/“
Alias / „/opt/otobo/bin/cgi-bin/“DocumentRoot /opt/otobo/bin/cgi-bin/
# Setup environment and preload modules
PerlOptions +Parent
Perlrequire /opt/otobo/scripts/apache2-perl-startup.pl# Reload Perl modules when changed on disk
PerlModule Apache2::Reload
PerlInitHandler Apache2::Reload# general mod_perl2 options
DirectoryIndex index.pl
AddHandler perl-script .pl .cgi
ErrorDocument 403 /otobo/index.pl
#SetHandler perl-script
PerlResponseHandler ModPerl::Registry
Options +ExecCGI
PerlOptions +ParseHeaders
PerlOptions +SetupEnvOrder allow,deny
Allow from all= 2.4>
Require all grantedOrder allow,deny
Allow from all# mod_perl2 options for GenericInterface
PerlOptions -ParseHeaders
ServerName suporte.mydomain.com
#ErrorLog logs/customer.mydomain.com-error_log
#CustomLog logs/customer.mydomain.com-access_log common
DocumentRoot /opt/otobo/bin/cgi-bin/# ErrorDocument 403 /otobo/customer.pl
DirectoryIndex customer.pl
#AddHandler perl-script .pl .cgi
Options +ExecCGI
Allow from all<Directory „/opt/otobo/bin/cgi-bin/“>
AllowOverride None
Options +ExecCGI -IncludesOrder allow,deny
Allow from allAddOutputFilterByType DEFLATE text/html text/javascript application/javascript text/css text/xml application/json text/json
<Directory „/opt/otobo/var/httpd/htdocs/“>
AllowOverride NoneOrder allow,deny
# Make sure CSS and JS files are read as UTF8 by the browsers.
AddCharset UTF-8 .css
AddCharset UTF-8 .js# Set explicit mime type for woff fonts since it is relatively new and apache may not know about it.
AddType application/font-woff .woff# Allow access to public interface for unauthenticated requests on systems with set-up authentication.
# Will work only for RegistrationUpdate, since page resources are still not be loaded.
# Order allow,deny
# Allow from all
# = 2.4>
# Require all granted
# Order allow,deny
# Allow from all
## Cache css-cache for 30 days
<Directory „/opt/otobo/var/httpd/htdocs/skins/*/*/css-cache“>
<FilesMatch „\.(css|CSS)$“>
Header set Cache-Control „max-age=2592000 must-revalidate“# Cache css thirdparty for 4 hours, including icon fonts
<Directory „/opt/otobo/var/httpd/htdocs/skins/*/*/css/thirdparty“>
<FilesMatch „\.(css|CSS|woff|svg)$“>
Header set Cache-Control „max-age=14400 must-revalidate“# Cache js-cache for 30 days
<Directory „/opt/otobo/var/httpd/htdocs/js/js-cache“>
<FilesMatch „\.(js|JS)$“>
Header set Cache-Control „max-age=2592000 must-revalidate“# Cache js thirdparty for 4 hours
<Directory „/opt/otobo/var/httpd/htdocs/js/thirdparty/“>
Header set Cache-Control „max-age=14400 must-revalidate“# Limit the number of requests per child to avoid excessive memory usage
MaxRequestsPerChild 4000Any help on this issue?
