    • 10. November 2020 um 9:20 Uhr - Views: 1192 #9923
      Enzo
        Dear Community,
        I would like to ask if anyone has had any success in stopping the solution timer (as defined by the SLA) when a ticket state is set to „on hold“? Right now, I can’t find a way to stop this timer.
        Your help would be appreciated.
        Kind regards,
        Enzo
      • 10. November 2020 um 10:17 Uhr #9925
        Sven Oesterling
        Administrator
          Hello Enzo,
          this should work, with the SysConfig option EscalationSuspendStates. You have to enable it, and potentially add your pending state to it. The daemon has to be running, also. Then every three minutes, or so, the escalation will be postponed for three minutes.
          Best regards, Sven
        • 10. November 2020 um 11:30 Uhr #9927
          Enzo
            Thanks Sven, that solved my problem, you’re a lifesaver!
