13. Juli 2021 um 14:59 Uhr - Views: 987 #11737
not sure if this error is bound to update to 10.0.11, but getting it after I created new phone ticket, in log is only
Tue Jul 13 14:57:43 2021 (Europe/Prague)
error
OTOBO-CGI-69
No such !Anyone getting same error ?
13. Juli 2021 um 15:15 Uhr #11738
Hm…now my answer was swallowed somehow…
I have not encountered this so far, but since the error message is a bit strange, I had a quick look, and I think that the only place where this short message could be logged is Kernel/System/Crypt/SMIME.pm. If you are using SMIME, please check whether especially the options SMIME::CertPath and SMIME::PrivatePath are set up correctly.
Hope this helps, Sven
13. Juli 2021 um 21:03 Uhr #11743
Hi Sven,
thanks for hint, I don´t use SMIME, SMIME::CertPath was disabled and SMIME::PrivatePath not. Then I disabled SMIME::PrivatePath too.
Will see if this solve the problem.
16. Juli 2021 um 13:07 Uhr #11756
Looks like it helped. Thanks for hint.
