Ansicht von 1 Antwort-Thema
- Das Thema „ Ticket State After closed“ ist für neue Antworten geschlossen.
Good Morning,
is it possible to set ticket state only open after ticket closed?
Example:
The user customer open the ticket, the agent close it. The customer user does a followup on same ticket (state closed), he can set three option:
I’d like set only open state. Is it possible?
Thank You
I have find a solution.
I have disabled this feature Ticket::Frontend::CustomerTicketZoom###State
Thank You
