    • #10426
      Alex Eaves
        I am trying to configure Otobo to use…
        support.mydomain.org
        …instead of…
        support.mydomain.org/otobo/index.pl
        I’ll even settle for…
        support.mydomain.org/index.pl
        Is this possible? Thank you.
      • #10427
        Alex Eaves
          I suppose the same goes for „customer.pl“
        • #10534
          Demian Kellermann
            I simply adapted the nginx configuration to redirect a plain request to the interface. In my case, the snippet is
            # always redirect to agent interface
            location ~ ^/$ {
            return 301 https://$host/otobo/index.pl;
          • #10804
            Martin Dvorsky
              does anybody know about more elegant solution instead of simply redirecting? Also is there any chance to make to this possible without using nginx?
              Thanks
            • #12036
              possebon Fernando
                It’s possible. I’ve done this.
                Assuming that you will have the following:
                • servicedesk.yourdomain.com – for the agent / management users
                • support.yourdomain.com – for the customer users
                You can use the following steps:
                • Copy the original zzz_otobo.conf to zzz_servicedesk_otobo.conf
                • Copy the original zzz_otobo.conf to zzz_support_otobo.conf
                • Rename the zzz_otobo.conf to zzz_otobo.original
                • Edit the zzz_servicedesk_otobo.conf and make the following changes (I’ll post only the relevant part of files, the original and the changed version):
                Original
                https://pastebin.com/FULHvVLk
                Changed version of zzz_servicedesk_otobo.conf:
                https://pastebin.com/rvCzhp5i
                Changed version of zzz_support_otobo.conf:
                https://pastebin.com/mubFxKM6
                Don’t forget to add the closing tag <strong></VirtualHost></strong> on both files.
                • Change the ScriptAlias to empty value on SysConfig
                I hope this helps.
                Best regards,
