Ansicht von 3 Antwort-Threads
Schlagwörter: DynamicField Attachment
hello
is it possible to make the attachment mandatory in the customer portal for a certain service ?
best regards
Hi Rio,
not the field of the article, but there is a DynamicField type attachment for that. You need the package „DynamicFieldAttachment“.
As you can define Dynamic Fields as mandatory, this might be the right thing for you.
Cheers
You need the package “DynamicFieldAttachment”.
how can i get this package ? since on my dynamic field types i do not have that option
you can find it in the Package Manager.
Cheers
