26. Januar 2023 um 15:30 Uhr - Views: 640 #14620
Hi everyone,
We are using OTOBO 10.0.15 and would like to automate a process.
For example, I would like to automatically send reminders to agents whose tickets are still in open status and the latest reply was by a customer.
If the reply from the customer is >= 3 days, a notification should be sent to that agent to check the ticket.
Is this possible and if so, how would I go on to automate that?
Thanks!
27. Januar 2023 um 13:01 Uhr #14623
Hello
You can check the escalation times for that. Maybe you want to use the Update Time.
Cheers
27. Januar 2023 um 14:54 Uhr #14624
Hi Stefan,
Thanks for the response.
Am I able to use the GenericAgent to create a job that will automatically add a note to each opened ticket if the last response has been from a customer and there hasn’t been a response from an agent in three days?
Thanks!
