Ansicht von 2 Antwort-Threads
Hi All,
Is there a way of removing the footer in the customer portal ?
It currently displays „designed by SanMiguel“
Thanks in advance
Andy
Hi Andy,
sorry the footer seem to be hardcoded. You can touch the HTML template files to remove this footer.
best regards,
~ kps
Hi all,
The outdated link to Sanmiguel has been removed in the latest versions (10.018 / 10.1.7).
Kind regards,
Grit
