30. Juni 2023 um 9:33 Uhr - Views: 569 #15344
For unknown reason the daemon stopped to send outgoing emails.
Incomming is working fine. Sending manually also fine.
How can I troubleshot this issue?
otobo@helpdesk:~$ ./bin/otobo.Console.pl Maint::Email::MailQueue –send –verbose
ERROR: OTOBO-otobo.Console.pl-Maint::Email::MailQueue-0 Perl: 5.32.1 OS: linux Time: Fri Jun 30 07:31:44 2023Message: Object already has an open Log for this type.
Traceback (70042):
Module: Kernel::System::CommunicationLog::_LogError Line: 563
Module: Kernel::System::CommunicationLog::ObjectLogStart Line: 213
Module: Kernel::System::Email::SMTP::Check Line: 56
Module: Kernel::System::Email::SMTP::Send Line: 232
Module: Kernel::System::Email::SendExecute Line: 762
Module: Kernel::System::MailQueue::Send Line: 711
Module: Kernel::System::Console::Command::Maint::Email::MailQueue::Send Line: 206
Module: Kernel::System::Console::Command::Maint::Email::MailQueue::Run Line: 155
Module: (eval) Line: 480
Module: ./bin/otobo.Console.pl Line: 35 -
30. Juni 2023 um 10:52 Uhr #15345
The error messsages are not totally related here.
Sometimes it sends without any error message (but only manually).
Message with ID ‚188910‘ successfully sent.
1 message(s) successfully sent!
Done.
