Schlagwörter:
    • #12043
      Docker Installation, Otobo Version 10.0.10
      I am trying to create a custom dashlet to display unclassified closed tickets.
      I was following these instructions
      https://www.ontec.at/otrs-ein-eigenes-dashlet-anlegen/
      And the dashlet is now available in the system configuration.
      But I am not able to create an appropriate list of attributes and/or filter to display only unclassified closed tickets.
      I was trying several combinations of attributes
      StateType=Closed;Type=Unclassified;SortBy=Age;
      and filters
      All, Type=Unclassified
      But the dasboard shows closed ticket regardless of the ticket type
      Can anyone help me to create the correct Attributes?
    • #12056
      Renée Bäcker
        Filter is the „tab“ in the widget. So it should be „All“.
        The attributes should look like
        StateType=closed;Type=Unclassified;SortBy=Age
        (lower case ‚c‘ for the StateType)
      • #12057
        Renée Bäcker
          And delete the caches after you have changed something. Otherwise you might get wrong results.
