Ansicht von 0 Antwort-Themen
Hi Guys,
I have been using the OTOBO and there is one item I like to modify but can’t find the place for the settings.
In the move dropdown menu in the ticket the number of charatcters is truncated as below (marked with green circle):
And when I type the characters the list does not show any words within the [..] making it difficult to select qeues from the list.
Is there any way to increase the width size to include all the characteres from the queues.
Thanks.
