30. Dezember 2020 um 20:58 Uhr - Views: 2787 #10431
i’ve a problem regarding sendmail.
I have the following error when i wan’t to send mails via my smarthost.
10
Kernel::System::Email::Sendmail
Sendmail check error: No such binary: /usr/sbin/sendmail!
30.12.2020 20:51:18 (Europe/Berlin)
11Kernel::System::Email
Error sending message using backend ‚Kernel::System::Email::Sendmail‘.
12Kernel::System::MailQueue
Message could not be sent! Error message: No such binary: /usr/sbin/sendmail!
13Kernel::System::MailQueue
Temporary problem returned from server, requeuing message for sending. Message: SMTPCode: -, ErrorMessage: No such binary: /usr/sbin/sendmail!
30.12.2020 20:51:18 (Europe/Berlin)What i’m missing?
Do i have to install sendmail in my docker?Best regards
Markus
14. Januar 2021 um 8:28 Uhr #10552
Hi Markus,
Please excuse the late reply, we are currently a bit stretched with answering OTOBO related queries on all channels.
I think the easiest solution is, configure a SMTP Host to send E-Mails. Please go to Admin -> System Configuration and Search for „Sendmail“. In the next step choose SMTPS or SMTPTLS and configure your mail gateway.
Best wishes from Germany!
17. Januar 2021 um 17:59 Uhr #10571
Hi Stefan,
thanks for the hint.
Yes i was in the wrong config.Now it works fine.
Thanks,
Markus
9. Januar 2022 um 0:23 Uhr #12441
OTOBO Team,
SMTP mails are stuck in processing in the queue, this occurred after the Customer<–>Groups feature was enabled. After resetting the Customer<–>Groups back to disabled, in Admin-> Communication the SMTP does not show up under Failing accounts as it normally did with a tick. However under the option Open communications all SMTP communication are stuck in the queue over 1465 mails. The SendmailModule is set to: Kernel::System::Email::SMTP. The smtp port set to 25. I can telnet successfully to the exchange server.
Any advice would be great
18. November 2023 um 0:16 Uhr #15928
Markus, can you share at a greater level of detail how you solved this, I have the same problem and I went to system configuration but what specific module did you have to manipulate to solve this?
