    • 15. Februar 2024 um 11:56 Uhr - Views: 982 #29691
      Takashi YANO
        We are using the following tow ticket states for working tickets:
        • wait for user’s response
        • working
        Is it possible to change the state from „wait for user’s response“ to „working“ when a customers put response to their ticket ?
      • 16. Februar 2024 um 16:09 Uhr #29946
          The state that is set, is defined in the setting PostmasterFollowUpState
          Here you could change it globally. If you would like to have it depending on the current state of the ticket, you might need a Postmaster Filter + a Generic Agent to do that. But that might be not so easy.
          Cheers
        • 17. Februar 2024 um 11:07 Uhr #29954
          Takashi YANO
            Thanks, I will try.
