    • 10. Mai 2021 um 13:28 Uhr - Views: 2168 #11480
      Przemysław Wilkosz
        Hello!
        Got a question about OTOBO translations (10.0.10 migrated from OTRS 6.0.30)
        I have registered on translate.otobo.org, downloaded polish translation file („Download original translation file (gettex PO file)“). Made some translations and fixed some typos in current ones and uploade it to review.
        Main questions is how to rebuild translations on already installed instance of OTOBO? I was following this developer manual – translations and nothing changed – I cannot see, my translations
        1. I’ve replaced file i18n/otobo/otobo.pl.pl with my new translations.
        2. I’ve run bin/otobo.Console.pl Dev::Tools::TranslationsUpdate  command from otobo user
        3. There was no errors during execution
        4. I’ve cleared cached data bin/otobo.Console.pl Maint::Cache::Delete
        5. Just in case Apache was restarted
        And nothing happed. I’ve tried to rebuild assets but script /opt/otobo/bin/otobo.WebServer.pl does not exists. Where I made a mistake/what I missed?
        Thank you for you help.
        Regards
        Przemek
      • 10. Mai 2021 um 17:10 Uhr #11481
        Grit Rother
        Administrator
          Hi Przemek,
          I don’t know about the specific processes described in the developer manual, I’m afraid.
          However, I hope I can contribute a little bit nevertheless towards solving your problem:
          1. In Weblate, great part of the Polish project is marked as „needing action“ now, which probably isn’t really how this process is supposed to work. However, I’ll ask our Polish partners to have a look at the translations and validate your changes.
          2. As soon as your suggestions have been validated, they should be fed back to GitHub automatically the following night. Maybe this provides you with an option of getting your translations into your system?
          3. At the longer run, they will be available in OTOBO 10.0.11 as well.
          Maybe someone else can help with the specifics of changing language files directly in OTOBO.
          All the best,
          Grit
        • 11. Mai 2021 um 9:09 Uhr #11482
          Przemysław Wilkosz
            That was my first time when I was using weblate. Probably misunderstand weblate documentation and marked wrong parameters while uploading translations.
            Thank You!
            Regards
            Przemek
          • 11. Mai 2021 um 11:05 Uhr #11483
            Przemysław Wilkosz
              Seems that translations works fine! I forgot that I have made some changes in pl.pm and placed it Custom/Kernel/Language/pl.pm. After deleting this file all translations made in i18n/otobo/otobo.pl.po works like a charm! Too many changes at once and I have lost ;)
              So case can be closed. Just waiting for info how to properly upload further translations.
              Regards
              Przemek
