Schlagwörter: Docker, MariaDB, max_allowed_packet
    • 1. März 2021 um 14:00 Uhr - Views: 2681 #10978
      Roy Sigurd Karlsbakk
        Hi all
        We have some old OTRS systems and we plan to migrate to Otobo. On those OTRS machines, the databases are rather large (16GB+). Therefore, we have set –max_allowed_packet=2G. Docker inspect otobo_db_1  gives me this
        „Args“: [
        „–max-allowed-packet=68157440“,
        Is there an easy way to change this?
      • 1. März 2021 um 17:34 Uhr #10981
          Hi Roy,
          max_allowed packet is set via the command line when starting the database server. You can adapt the settings in the file docker-compose/otobo-base.yml  in your checked out docker-compose repository. After the change you must restart the database with docker-compose restart db  (untested).
          Note that MariaDB supports packages only up to 1GB, see  https://mariadb.com/docs/reference/es/system-variables/max_allowed_packet/ .
          Best regards,
