Schlagwörter: Loading YAML string
Ansicht von 5 Antwort-Threads
    • 9. Dezember 2023 um 11:50 Uhr - Views: 978 #29638
      Hristo Hristov
        Hello, Otobo Forum ,
        In the last couple of days I receive those kind of error logs in my otobo log system:
        https://ibb.co/PgmtnX9  You can see the log errors here.
        Otobo version is 10.0.18 installed on Ubuntu .
        Also I installed YAML::XS Module and it is up to date.
        Mail Notification from otobo error:
        ERROR: OTOBO-otobo.Daemon.pl – Daemon Kernel::System::Daemon::DaemonModules::SchedulerTaskWorker-16 Perl: 5.30.0 OS: linux Time: Sat Dec  9 11:36:48 2023
        Message: Loading the YAML string failed:
        Traceback (713009):
        Module: Kernel::System::YAML::Load Line: 125
        Module: Kernel::System::SysConfig::DB::DefaultSettingListGet Line: 1398
        Module: Kernel::System::SysConfig::ConfigurationListGet Line: 3057
        Module: Kernel::System::SysConfig::ConfigurationInvalidList Line: 3244
        Module: (eval) Line: 145
        Module: Kernel::System::Daemon::DaemonModules::SchedulerTaskWorker::AsynchronousExecutor::Run Line: 125
        Module: (eval) Line: 386
        Module: main::Start Line: 386
        Module: bin/otobo.Daemon.pl Line: 164
        Message: YAML data was: „— |2
        Dear Customer,
        Unfortunately we could not detect a valid ticket number
        in your subject, so this email can’t be processed.
        Please create a new ticket via the customer panel.
        Thanks for your help!
        Your Helpdesk Team
        Traceback (713009):
        Module: Kernel::System::YAML::Load Line: 133
        Message: YAML data was not readable even by pure-perl YAML module
        Traceback (713009):
        Module: Kernel::System::YAML::Load Line: 144
        Message: Loading the YAML string failed: YAML::XS::Load Error: The problem:
        found character that cannot start any token
        was found at document: 1, line: 2, column: 2
        while scanning for the next token at line: 2, column: 2
        Traceback (713009):
        [% Data.Salutation | html %]
        [% Data.StdResponse | html %]
        [% Data.Signature | html %]
        [% Data.CreateTime | Localize(„TimeShort“) %] – [% Data.OrigFromName | html %] [% Translate(„wrote“) | html %]:
        [% Data.Body | html %]
        Traceback (713009):
        Message: Data was only readable pure-perl YAML module, please contact the System Administrator to update this record, as the stored data is still in a wrong format!
        Traceback (713009):
        Module: Kernel::System::YAML::Load Line: 150
        Please give me some hints.
      • 21. März 2024 um 15:03 Uhr #30018
        Rene Rohe
          I have the same issue. Some help regarding this problem would be nice.
          I already searched almost all SysConfig Parameters if something is off, but couldnt find any
        • 21. März 2024 um 17:44 Uhr #30021
            Somehow this reads as if something is wrong with the setting Ticket::Frontend::ResponseFormat. Is it still default?
            Cheers
          • 22. März 2024 um 6:09 Uhr #30022
            Rene Rohe
              yes I still have the value on default. I also reset this value multiple times and deployed the config with no success.
              I migrated from OTRS6 which already had this error and now after migration it is present in my OTOBO Docker installation.
              I also tried to find something in the old system but couldn´t find anything unfortunately.
            • 22. März 2024 um 13:45 Uhr #30025
                Do you get any error message if you do a bin/otobo.Console.pl Maint::Config::Rebuild ? What habbens if you do a bin/otobo.Console.pl Admin::Config::ListInvalid and maybe afterwards an bin/otobo.Console.pl Admin::Config::FixInvalid ?
                Cheers
              • 25. März 2024 um 6:15 Uhr #30028
                Rene Rohe
                  If i run all three commands, they all print the same YAML Errors. The result of the two commands „ListInvalid“ and „FixInvalid“ is stated as if everything is ok in the configuration.
                  Even when using the ::Rebuild –cleanup command it prints out the YAML Errors. Mostly on the second run of any of these commands.
                  Best Regards
                  Rene
