    • 9. August 2020 um 16:42 Uhr - Views: 970 #8672
      hilocz
        I was trying to run Otobo on same server, where is current OTRS installed. I set OTOBO_WEB_ROOT_HTTPS_PORT=8443 , but nginx didn´t started complaining about port conflict on port 443.
        David
      • 10. August 2020 um 10:40 Uhr #8677
          Hi David,
          thanks for your report. This is most likely a copy &paste error in the OTOBOO documentation. We are fixing that.
          The actual name ot the variable in .env is OTOBO_WEB_HTTPS_PORT. It is used for mapping of the Docker internal port 443 to the externally visible port. See the file docker-compose/otobo-override-https.yml .
          Best regards,
          Bernhard Schmalhofer
          • 10. August 2020 um 11:47 Uhr #8679
            hilocz
              Thanks for reply, it´s working now after I changed the variable.
