    • 20. November 2026 um 13:46 Uhr - Views: 22 #45917
      Grit Rother
        Mitigate Java4Shell in Elasticsearch (CVE-2026-114938)
        Elasticsearch’s Base64 parser is affected by CVE-2026-114938 (https://www.elastic.co/blog/java4shell-remote-code-execution-rce-vulnerability).
        We will release updates to the containers for OTOBO, as soon as they become available.
        In the meantime, you should deactivate the vulnerable parser optimization. This will slightly reduce index performance but entails no loss of functionality.
        For OTOBO Docker
        cd /opt/otobo-docker
        sed -i.bak '/^OTOBO_ELASTICSEARCH_ES_JAVA_OPTS=/{/UseBASE64Intrinsics/!s/[[:space:]]*$/ -XX:-UseBASE64Intrinsics/;}' .env
        grep UseBASE64Intrinsics .env
        docker compose up --detach --force-recreate elastic
        # verify
        sleep 20
        docker compose exec elastic curl --silent 'http://localhost:9200/_nodes/jvm?filter_path=nodes.*.jvm.input_arguments&pretty' | grep UseBASE64Intrinsics
        For OTOBO Podman
        # change to the otobo shell
        machinectl shell otobo@
        # in the shell
        cd ~/otobo-podman
        sed --in-place=.bak '/^OTOBO_ELASTICSEARCH_ES_JAVA_OPTS=/{/UseBASE64Intrinsics/!s/[[:space:]]*$/ -XX:-UseBASE64Intrinsics/;}' .env
        scripts/install.sh
        grep --recursive UseBASE64Intrinsics ~/.config/otobo/
        systemctl --user restart otobo-elastic
        # verify
        podman exec otobo-elastic curl --silent 'http://localhost:9200/_nodes/jvm?filter_path=nodes.*.jvm.input_arguments&pretty' | grep UseBASE64Intrinsics
        The last line should show "-XX:-UseBASE64Intrinsics",.
