24. Februar 2022 um 16:30 Uhr - Views: 1565 #12705
After migrating from OTRS, our OTOBO (10.0.15) is showing the following error on System Log:
Can’t locate Kernel/Output/HTML/ITSMConfigItemMenuGeneric.pm in @INC (you may need to install the Kernel::Output::HTML::ITSMConfigItemMenuGeneric module) (@INC contains: /opt/otobo/Custom /opt/otobo/Kernel/cpan-lib /opt/otobo/ /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.30.0 /usr/local/share/perl/5.30.0 /usr/lib/x86_64-linux-gnu/perl5/5.30 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.30 /usr/share/perl/5.30 /usr/local/lib/site_perl /etc/apache2) at /opt/otobo/Kernel/System/Main.pm line 113.
I have searched all over, but can’t find information on this error. Has anyone encountered this error, or has any idea how to deal with it?
25. Februar 2022 um 15:08 Uhr #12716
Do you have still a ZZZAAuto.pm in the Kernel/Config/Files directory? Can you do a grep?
$ grep -r „TSMConfigItemMenuGeneric“ Kernel/Config*
It’s likely a leftover from older OTRS versions. Each „::ITSMConfigItemMenuGeneric“ should be a „::ITSMConfigItem::MenuGeneric“
