    • 12. März 2023 um 14:38 Uhr - Views: 653 #14875
      muaz elshikh
        how can i linke a specific field with a specific ticket
      • 21. März 2023 um 19:22 Uhr #14961
          I’m not sure what exactly you would like to do, but depending on your use case you could use the „Show link“ function in Dynamic Fields (e.g. type Text): https://doc.otobo.org/manual/admin/10.1/en/content/processes-automation/dynamic-fields.html#text-dynamic-field-settings
          Here you can hardcode a link which will work as soon as the DF has a value (and is shown in AgentTicketZoom). You can also have a dynamic part in the link if you want to use the value of the field itself or of another field.
          Cheers,
