Ansicht von 0 Antwort-Threads
2. April 2025 um 16:14 Uhr - Views: 406 #34776
Hello!
I am using the Demo in Web. At the moment, we are setting up an test environment, but I have a number of questions that I cannot find answers to. If there is a different channel I should use please let tell me.
- Tickets appear to be a single object type, and different fields are displayed depending on the request type. (incident Service Request, Change) Is this correct?
- How do I tell in the list if a ticket is an Incident, ChangeRequest or ServiceRequest?
- How do I search for only ChangeRequests, for example?
- How do I filter or group the dashboard views?
- How do I change color of entries in list based on various criteria.
- Ticket is red if deadline passed.
- Configuration Item red if contact will expired in less than one month.
- Can I create our own states based on ticket type
- All tickets have a review state.
- CR has a planning state, but Incident does not.
- Priority is the combination of impact and urgency, but I only see a priority field. Where are impact and urgency? Can I add them and create a new calculated field for priority.
Work-Flows
- Workflow editor. Is there really an visual editor? Is it BPMN compatible?
- Can I define criteria for different states, e.g. you can only move a change ticket from planning to approval if you are the ticket owner.
Activities/Tasks – An activity is a seperate object used to manage the actual work.
- Someone is responsible for a change request, but other people are responsible for the actual doing. How does one keep track of that?
- Can you define templates for changes? For example
- CR type 1 has 10 different activities.
- CR type 2 has 7 different activities.
How do I assign a category to a ticket?
Are categories the same as the FAQs? That is, is there a single category tree?
KnowledgeManagement- Is the Wiki simply FAQs?
- We have the following types HowTo/FAQ, Standard Solutions, Known-Errors, Directives
- We want to differentiate between type and category. (e.g. in a search, show all HowTos related to Outlook)
Integration with Baramundi
- Import/compare CMDB at regular intervals
- Delete old, add new items
- Is it explicitely a Baramundi API/Connector or is it building a new „Webservice“
- The Otobo home page says „Automated Population of the Configuration Management Database“
- Is this „plugin and go“ or does the admin have to actually script the interface.
- In other ticket systems, you just define the field mappings
Change Management
- Multi-Level, multi-step Approval
- For example: Customer/Dept. manager, IT, Customer/Dept. manager again
SSP Pages
- Is there a Kiosk/Shop-Function? For example, to order new hardware.
- Does this have an approval function?
Processes/Process tickets
- We need multiple Process similar to „Service Catalog“. Example On-Boarding.
- Why is the list of required information not just automatically added to the ticket? Better yet, why are these not dynamic fields?
- Can you create a change request or service request directly from an Incident.
- Differentiate an Event from an Incident
Can we define own Forms?
- Define new fields for these forms?
- Can the forms be dynamically assigned, for example if the current user is in the Group KeyUsers, then show form F1, otherwise show form F2.
Setting the characteristics of Fields:
- Only writeable if ticket in a specific state.
- Only visible if users is a member of a specific group.
- Mandatory if ticket is in a specific state.
- Only writeable if users is a member of a specific group.
- Only writeable if another field has a specific value.
