Schlagwörter: Need Key
2. Juni 2021 um 13:28 Uhr - Views: 1139 #11519
Hi
I’m getting this Error on log, I’ve found the configuration that was need to disable on a similar error that I had but with the „Message: Need Module“ by using this script: https://gist.github.com/reneeb/3aca0b607baf1b2ce2d2524ad4a9f139
Is there a similar script to find this?Traceback (174055):
Module: Kernel::System::Main::Require Line: 85
Module: Kernel::Output::HTML::Layout::NavigationBar Line: 3321
Module: Kernel::Modules::AgentTicketZoom::Run Line: 826
Module: Kernel::System::Web::InterfaceAgent::Run Line: 1257
Module: ModPerl::Registry::handler (v1.99) Line: 32ERROR: OTOBO-CGI-15 Perl: 5.30.0 OS: linux Time: Wed Jun 2 07:27:34 2021
Message: Need Key!
4. Juni 2021 um 10:28 Uhr #11524
This is very unlikely the stacktrace for the given message. Can you check the error log and share the traceback that is *after* the error message?
8. Juni 2021 um 10:30 Uhr #11571
Hi!
Thank you for your reply.The following log after the error message:
Message: Need Key!
RemoteAddress: 192.168.5.100
RequestURI: /otobo/index.plTraceback (102903):
Module: Kernel::System::Cache::Get Line: 295
Module: Kernel::System::Web::InterfaceAgent::Run Line: 265
Module: ModPerl::Registry::handler (v1.99) Line: 32 -
8. Juni 2021 um 11:34 Uhr #11574
The second trace is something that has to be tidied by us and is quite certainly unrelated (you seemingly called Action=Login without providing any user, which usually should be prevented by the validation check of the js before even getting there) – for the first one please check your SysConfig for ‚Frontend::NotifyModule‘ and check if all modules called there really exist.
Best regards, Sven
