Schlagwörter: Need Module
18. Mai 2021 um 12:28 Uhr - Views: 1334 #11496
Hi.
Is there a best way to fix this error? I get recurrently the message “ Message: Need module!“, this was a installation that previously had a Commercial OTRS license, I’ve search for every entry on AgentTicketQueue and AgentTicketZoom to remove all entries that I could find that we’re not using.
18. Mai 2021 um 14:03 Uhr #11497
Hi Miguel,
please check the webserver error log. There you should see more information where this error occurs.
Regards
Renée -
21. Mai 2021 um 10:48 Uhr #11505
Thank you for your reply.
Not really :(
==> /var/log/apache2/error.log <==
ERROR: OTOBO-CGI-15 Perl: 5.30.0 OS: linux Time: Fri May 21 08:45:43 2021Message: Need module!
RemoteAddress: 192.168.5.100
RequestURI: /otobo/index.pl?Action=AgentTicketQueueTraceback (18822):
Module: Kernel::System::Main::Require Line: 85
Module: Kernel::Output::HTML::Layout::NavigationBar Line: 3321
Module: Kernel::Modules::AgentTicketQueue::Run Line: 194
Module: Kernel::System::Web::InterfaceAgent::Run Line: 1257
Module: ModPerl::Registry::handler (v1.99) Line: 32ERROR: OTOBO-CGI-15 Perl: 5.30.0 OS: linux Time: Fri May 21 08:45:43 2021
Module: ModPerl::Registry::handler (v1.99) Line: 32 -
2. Juni 2021 um 11:28 Uhr #11516
Try to run this script: https://gist.github.com/reneeb/3aca0b607baf1b2ce2d2524ad4a9f139
2. Juni 2021 um 11:56 Uhr #11518
Thank you so much, that simply worked!
I could found the modules that we’re not using anymore but still were in the configuration.
Thank you again, this solved issue that had years. :)
