    • 22. März 2023 um 10:48 Uhr - Views: 1070 #14965
      Mikołaj Pawelec
        I have a question. Is it possible to send e-mails trough exchange online without using SMTP relay? If yes then what should be configured first? I configured Oauth2 for OTOBO, and I am receiving e-mails on queues, but i cannot respond clients from them. Configuration for SMTP is shown on a screen below :
      • 23. März 2023 um 9:27 Uhr #14977
        kps
          Hi Mikołaj Pawelec,
          oAuth2 is currently not implemented for sending mail. You can try to enable plain SMTP auth at Microsoft to send via SMTP directly. Otherwise you need a relay server.
          If you like you can send a mail to hallo@otobo.de to get an estimate for the implementation.
          i hope i could help you for now.
          best regards,
          ~ kps
        • 23. März 2023 um 12:24 Uhr #14979
          Mikołaj Pawelec
            Ok, thanks
