    • 18. Juni 2024 um 15:47 Uhr - Views: 588 #31156
      Andrea Saffioti
        When selecting X Axis in any stats (even in newly created ones) the Owner and Responsible fields are mssing from the dropdown menu of „Attributes to be printed“.
        I think this is a bug as I was not able to find any setting in the sysconfig.
        Anyone can confirm the same behaviour or has a solution?
        Thank you
      • 9. Juli 2024 um 9:49 Uhr #31455
        Andrej Hujo
          Hi, i thought it’s a bug.
          But u need it to enable in sys config: Stats::UseAgentElementInStats
          Hope it helps.
          //AH
        • 24. Juli 2024 um 12:21 Uhr #31729
          Andrea Saffioti
            Thank you Andrej.
            It worked!
            Just to be helpful for others, after enabling the setting you need to create a new Statistics and those fields will appear in the list of attributes to be printed.
            • Diese Antwort wurde vor 2 Jahren, 1 Monat von Andrea Saffioti geändert.
