Schlagwörter: Daemon SQL Mail Worker
15. August 2023 um 11:22 Uhr - Views: 735 #15522
Hallo zusammen.
Hab jetzt schon länger gewühlt, komme aber nicht wirklich weiter.
Seit einigen Tagen bekomme ich schön im 10 Minuten Abstand Mails vom Scheduler Daemon:
Betreff "OTOBO Scheduler Daemon Cron: StatsReportsGenerateCron"
Error: Unable to register the process in the database. Is another instance still running?
You can use --force-pid to override this check.Angefangen hat es mit einer Mail, die einen SQL-Fehler enthielt:
DBD::mysql::db do failed: Lock wait timeout exceeded; try restarting transaction at /opt/otobo/Kernel/System/DB.pm line 560.
ERROR: OTOBO-otobo.Console.pl-Maint::Stats::Reports::GenerateCron-98 Perl: 5.34.0 OS: linux Time: Sun Aug 13 08:11:26 2023
Message: Lock wait timeout exceeded; try restarting transaction, SQL: '
DELETE FROM process_id
WHERE process_name = ?
AND process_host = ?'
Traceback (180040):
Module: Kernel::System::PID::PIDDelete Line: 232
Module: Kernel::System::Console::Command::Maint::Stats::Reports::GenerateCron::PostRun Line: 196
Module: (eval) Line: 487
Module: Kernel::System::Console::BaseCommand::Execute Line: 487
Module: (eval) Line: 155
Module: Kernel::System::Daemon::DaemonModules::SchedulerTaskWorker::Cron::Run Line: 134
Module: (eval) Line: 386
Module: main::Start Line: 386
Module: /opt/otobo/bin/otobo.Daemon.pl Line: 164Log /opt/otobo/var/log/Daemon/SchedulerTaskWorkerERR.log zeigt:
...ERROR: OTOBO-otobo.Console.pl-Maint::Stats::Reports::GenerateCron-98 Perl: 5.34.0 OS: linux Time: Tue Aug 15 07:50:19 2023Message: There was an error executing Execute() in Kernel::System::Console::Command::Maint::Stats::Reports::GenerateCron: Error: Unable to register the process in the database. Is another instance still running?
You can use --force-pid to override this check.Traceback (22177):
Module: Kernel::System::Daemon::DaemonModules::BaseTaskWorker::_HandleError Line: 60
Module: Kernel::System::Daemon::DaemonModules::SchedulerTaskWorker::Cron::Run Line: 189
Module: /opt/otobo/bin/otobo.Daemon.pl Line: 164Habe die Datenbank (mysql) auf Locks (
SHOW OPEN TABLES) und hängengebliebene Prozesse (show full processlist) geprüft, sehe aber nichts.Es laufen „normal viele“ Daemonprozesse und deren Registrierung scheint zu stimmen.
bin/otobo.Console.pl Maint::Daemon::ListListing system daemons...
SchedulerCronTaskManager
SchedulerFutureTaskManager
SchedulerGenericAgentTaskManager
SchedulerTaskWorker
SystemConfigurationSyncManager
Done.root@...:~# ps -eo args | grep otobo | head -n -1
perl bin/otobo.Daemon.pl start
perl bin/otobo.Daemon.pl startAlle anderen Worker laufen normal durch …
bin/otobo.Console.pl Maint::Daemon::SummaryGathering summary for all daemons...System configuration sync:
Daemon is active.Tasks to be executed in future:
| Name | Type | To Execute At |
+------+-------------------+---------------------+Recurrent cron tasks:
| Name | Last Execution | Last Status | Last Duration | Next Execution |
| ArticleSearchIndexRebuild | 2023-08-15 07:56:00 | Success | < 1 Second | 2023-08-15 07:57:00 |
| CommunicationLogDelete | 2023-08-15 03:00:00 | Success | < 1 Second | 2023-08-16 03:00:00 |
| ConfigurationDeploymentCleanup | 2023-08-13 00:40:00 | Success | < 1 Second | 2023-08-20 00:40:00 |
| CoreCacheCleanup | 2023-08-13 00:20:00 | Success | 1.0 Second(s) | 2023-08-20 00:20:00 |
| EscalationCheck | 2023-08-15 07:55:00 | Success | < 1 Second | 2023-08-15 08:00:00 |
| GenerateDashboardStats | 2023-08-15 07:05:00 | Success | < 1 Second | 2023-08-15 08:05:00 |
| GeneticInterfaceDebugLogCleanup | 2023-08-15 03:02:00 | Success | < 1 Second | 2023-08-16 03:02:00 |
| LoaderCacheDelete | 2023-08-13 00:30:00 | Success | < 1 Second | 2023-08-20 00:30:00 |
| MailAccountFetch | 2023-08-15 07:50:00 | Success | 2.0 Second(s) | 2023-08-15 08:00:00 |
| MailQueueSend | 2023-08-15 07:56:00 | Success | < 1 Second | 2023-08-15 07:57:00 |
| RebuildEscalationIndex | 2023-08-15 07:56:00 | Success | < 1 Second | 2023-08-15 08:00:00 |
| RegistrationUpdateSend | 2023-08-15 07:30:00 | Success | < 1 Second | 2023-08-15 08:30:00 |
| RenewCustomerSMIMECertificates | 2023-08-15 02:02:00 | Success | < 1 Second | 2023-08-16 02:02:00 |
| SessionDeleteExpired | 2023-08-15 06:55:00 | Success | < 1 Second | 2023-08-15 08:55:00 |
| SpoolMailsReprocess | 2023-08-15 00:10:00 | Success | < 1 Second | 2023-08-16 00:10:00 |
| StatsReportsGenerateCron | 2023-08-15 07:50:00 | Fail | < 1 Second | 2023-08-15 08:00:00 |
| SupportDataCollectAsynchronous | 2023-08-15 07:01:00 | Success | < 1 Second | 2023-08-15 08:01:00 |
| TicketAcceleratorRebuild | 2023-08-15 01:01:00 | Success | < 1 Second | 2023-08-16 01:01:00 |
| TicketDraftDeleteExpired | 2023-08-15 07:55:00 | Success | < 1 Second | 2023-08-15 08:55:00 |
| TicketNumberCounterCleanup | 2023-08-15 07:50:00 | Success | < 1 Second | 2023-08-15 08:00:00 |
| TicketPendingCheck | 2023-08-15 06:45:00 | Success | 1.0 Second(s) | 2023-08-15 08:45:00 |
| TicketUnlockTimeout | 2023-08-15 07:35:00 | Success | < 1 Second | 2023-08-15 08:35:00 |
| WebUploadCacheCleanup | 2023-08-15 07:46:00 | Success | < 1 Second | 2023-08-15 08:46:00 |
| DeleteExpiredOTATokens | 2023-08-15 04:00:00 | Success | < 1 Second | 2023-08-16 04:00:00 |
+---------------------------------+---------------------+-------------+---------------+---------------------+Recurrent generic agent tasks:
+-------------------------------+---------------------+-------------+---------------+---------------------+Unhandled Worker Tasks:
There are currently no tasks waiting to be executed.Handled Worker Tasks:
There are currently no tasks being executed.Done.Hat jemand einen Tip, wo ich hingreifen muss?
Hat sich da was in der Datenbank verhaspelt?
Gibt es irgendwelche Aufräumtasks die ich probieren kann?
VG,
Andrej
15. August 2023 um 11:28 Uhr #15523
Nachtrag. Systemlog sagt …
Tue Aug 15 11:20:20 2023 (Europe/Berlin) error OTOBO-otobo.Console.pl-Maint::Stats::Reports::GenerateCron-98 There was an error executing Execute() in Kernel::System::Console::Command::Maint::Stats::Reports::GenerateCron: Error: Unable to register the process in the database. Is another instance still running?
Tue Aug 15 11:20:20 2023 (Europe/Berlin) notice OTOBO-otobo.Console.pl-Maint::Stats::Reports::GenerateCron-98 Can’t create PID Maint::Stats::Reports::GenerateCron, because it’s already running (SERVERFQDNHIER/180040)!
17. August 2023 um 13:27 Uhr #15534
Update.
Leider oder zum Glück hat sich das Problem erledigt.
Leider weil ich nicht sagen kann, was die Lösung war – vermutlich lief irgendein Systemswartungsjob der Sessions / alte PIDs weggeräumt hat? Ich habe in dem Moment lediglich Fehlersuche betrieben ohne etwas zu verändern.
Falls jemandem noch etwas dazu einfällt gerne noch Tips ergänzen.
