Schlagwörter: installation
26. Januar 2021 um 17:17 Uhr - Views: 1594 #10625
Good evening,
I’m newbie with OTOBO.
I’m tring install it on my VM with Ubuntu Server 20.04.
I have followed all documentation commands but when I try connect to this page http://localhost/otobo/installer.pl, nothing.
I have configured my apache server with these commands:
root> cp /opt/otobo/scripts/apache2-httpd-vhost-80.include.conf /etc/apache2/sites-available/zzz_otobo-80.conf
root> a2ensite zzz_otobo-80.conf
root> systemctl restart apache2
In zzz_otobo-80.conf I have replace FQDN with my ip local machine.
Thank You for your support
Best regards
27. Januar 2021 um 15:07 Uhr #10628
I have resolve the problem…
I have installed Otobo docker version…:-)
We are using OTRS version 3.3.x.
I have read the installation guide and it is possible migration from OTRS Community/OTRS version 6.
Is it possible migration from OTRS 3.3.x version to Otobo?
Thank You for support
Best Regards
28. Januar 2021 um 9:39 Uhr #10629
Hi Giordano,
Brilliant, I’m glad to see your problems are solved.
As for migrating from OTRS 3 to OTOBO: You have to upgrade your OTRS first – from 3 to 4 to 5 to 6. But then you can migrate to OTOBO!
Hope this helps. Get in touch if you need further support.
Kind regards,
Grit
