Schlagwörter: backup and restore
    • 20. März 2023 um 17:42 Uhr - Views: 1457 #14938
      Gonçalo Faria
        I am trying to do something as simple as creating a backup on a main host, move it to secondary host with otobo fresh installed and restore the backup from the main host, trying to make a DR strategy basically.
        When i try to restore with otobo running i have this error message:
        ERROR: Already existing tables in this database. A empty database is required for restore!
        When it try to restore with otobo stopped i have this message:
        DBI connect(‚database=otobo;host=db‘,’otobo‘,…) failed: Unknown MySQL server host ‚db‘ (-3) at /opt/otobo_install/local/lib/perl5/DBIx/Connector.pm line 31.
        ERROR: OTOBO-restore.pl-08 Perl: 5.36.0 OS: linux Time: Mon Mar 20 16:23:38 2023
        Message: Unknown MySQL server host ‚db‘ (-3)
        Traceback (1):
        Module: Kernel::System::DB::Prepare Line: 775
        Module: /opt/otobo/scripts/restore.pl Line: 179
        Can’t call method „fetchrow_array“ on an undefined value at /opt/otobo/Kernel/System/DB.pm line 860.
        From the second message i assume it’s supposed to have it running, but should i wipe the DB before restoring?
        ps: i am following this guide https://doc.otobo.org/manual/installation/10.1/en/content/backup-restore.html
        Thank you very much,
        Best,
        Gf
      • 21. März 2023 um 10:54 Uhr #14943
          hello Gonçalo ,
          I only used the backup and restore on a docker based installation.
          Here I had to set the same database password for the new installation.
          mysql -u root -p
          Enter password: db password
          SET PASSWORD FOR ‚otobo‘ = PASSWORD(‚the old One‘);
          FLUSH PRIVILEGES;
          and i think you must drop the DB
          DROP DATABASE otobo;
          CREATE DATABASE otobo CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci;
          GRANT ALL PRIVILEGES ON otobo.* TO ‚otobo’@’%‘;
          Greetings,
        • 21. März 2023 um 18:02 Uhr #14953
          Gonçalo Faria
            Thank you for the answer,
            I managed to install the database, but i couln’t login with the root@localhost account from the original DB.
            I will try to do a fresh install with a root@localhost password equal to the original DB, to check if i can see the data restored.
            Thank you for the answer.
            Best,
            Gf
          • 21. März 2023 um 19:19 Uhr #14960
              If you don’t know the root@localhost password, you can always reset it with the bin/otobo.Console.pl
              Cheers,
