Schlagwörter: deployment
    • 6. April 2022 um 13:56 Uhr - Views: 1911 #13004
      P O
        Hey,
        I’ve been using Otobo for a while now, not having much experience with Perl and the OTRS/OTOBO system itself.
        Recently, when changing any settings in the configuration, it takes an unmercifully long time – then throws an error. Next, deployment – takes a long time, then an error that the deployment cannot be blocked for UserID=2. In the deployment list everything is seemingly ok, but a red bar appears – with an error: In the deployment list everything is seemingly ok, but a red bar appears – with an error:
        How to check and remove the deployment lockout? Where can I find more detailed logs, because the Apache2 error.log does not tell me anything:
        Message: Can not lock the deployment for UserID '2'!
        RemoteAddress: 192.168.255.1
        RequestURI: /otobo/index.pl?Action=AdminSystemConfigurationDeployment;Subaction=AJAXDeployment
        Traceback (16795):
        Module: Kernel::System::SysConfig::ConfigurationDeploy Line: 3566
        Module: Kernel::Modules::AdminSystemConfigurationDeployment::Run Line: 83
        Module: Kernel::System::Web::InterfaceAgent::Run Line: 1247
        Module: ModPerl::Registry::handler (v1.99) Line: 32
    • Otobo 11.1 – Mailabholung per OIDC Provider Profile – IMAPS anstatt IMAP
    • Otobo 11
