Schlagwörter: CustomerUsers Language Defaults
24. September 2021 um 17:49 Uhr - Views: 729 #11949
Hi
Is there a way to set the default Customer User Interface Language as default different from English ?
I tried System Configuration / Frontend / base _____ Default Language
But it don’t see how it works.
Instead another Customer User default settings (i.e. System Configuration / Core / time
UserDefaultTimeZone) works perfectly.Does anyone know how to fix it ?
Thank you very muche
Julian
27. September 2021 um 9:13 Uhr #11954
Ciao Giuliano,
io ho completato le traduzioni mancanti nel file Language.
Infatti ora la mia interfaccia è completamente italiana.
Se vuoi ti dico il percorso dove trovare il file.
Buona Giornata
27. September 2021 um 10:25 Uhr #11955
@Giordano: Grazie, sarebbe molto utile: lo implementerò volentieri !
Funzionerà beneone …ma con il default language giusto: aggiungo un PrintScreen perchè forse sono stato poco chiaro.
Grazie ancora :-)
Giul
27. September 2021 um 10:39 Uhr #11956
Here is the print-screen of the problem:
And here is the setting I don’t see working:
Thank you everyone !!
Giul
27. September 2021 um 12:00 Uhr #11957
This is my Customer User Page…
6. Oktober 2021 um 17:35 Uhr #11994
The default selected value is determined in this order:
* A query parameter „UserLanguage“ (e.g. https://yourotobo.tld/otobo/index.pl?Action=AdminCustomerUser;Subaction=Change;ID=tc;Search=*;Nav=;UserLanguage=it)
* The already set value for the language preference
* The agent language
* The default language
The third one is your problem.
