Ansicht von 2 Antwort-Themen
I created a Generic Agent Job Management on otobo to delete tickets and I wanted to know if it was possible to delete several tickets at the same time by targeting the ticket#?
For a single ticket it works but I can’t put multiple references.
Can you help me please?
Thank you in advance for your feedback,
Mehdi
Hi Mehdi,
try to use two pipes between the ticket numbers:
e.g.:
202205181012345||202205181012346
I guess that should work.
Cheers
It’s perfect, thanks for your feedback Stefan
