Schlagwörter: ACL Service
20. Februar 2024 um 8:08 Uhr - Views: 841 #29694
Hello.
I have created some services to appear in the customer portal ( self service portal ) and they are showing up.
i created a new service but it keeps getting the same dynamic fields as the other services, how can i specify wich dynamic fields correspond to certain services, or how can i create an ACL to remove them from the certain services ? it his inheriting the dynamic fields for some reason.
i created another service separated and it doesnt show up on the list as well, only if i set it up as a sub-service
can anyone help please?
20. Februar 2024 um 9:02 Uhr #29958
basicly i want for this new service to not add any dynamic
how it should be:
how its pops up:
i want to remove for this service the red part. but it keeps inherting it.
20. Februar 2024 um 18:14 Uhr #29961
Hi Rio,
You could e.g. create an ACL that hides the Dynamic Fields:
Possible Not > Form > [RegExp] .And then for each service create a new ACL to show the proper fields.
Properties > Ticket > Service > Question
Possible Add > Form > All the DF NamesPlease remember that the order of the ACL matters!
Have fun!
22. Februar 2024 um 8:55 Uhr #29966
hello.
thank you for the answer.
what about making attachments mandatory is it also a dynamic field ?
23. Februar 2024 um 15:26 Uhr #29975
If you create a Dynamic Field from type attachment, you define a name. And that ist the name you list in my point „All the DF Names“
27. Februar 2024 um 10:09 Uhr #29985
yeah but i dont have type attachment:
i cant create a dynamic field of that type, because that type doesnt show up.
27. Februar 2024 um 18:47 Uhr #29986
It’s a separate package you can find in the Package Manager.
Cheers
7. März 2024 um 9:45 Uhr #29992
thank you
