27. Mai 2025 um 20:35 Uhr - Views: 413 #35330
I’ve moved from the original OTRS Community Edition to Otobo 10.0 when I started a new job last year. OTRS had a package to enable adding URLs to the Agent interface NavBar or Menu Bar (main menu bar with Tickets, etc.) . I’ve been searching for a way to do this with Otobo and have come up short. Does any one know of a way to do this?
28. Mai 2025 um 16:35 Uhr #35331
Hi Michael,
have a look at the following two options in the System Configuration:
Admin UI > System Configuration > Frontend::Module###ExternalURLJump
and
Admin UI > System Configuration > Frontend::Navigation###ExternalURLJump###1
Enable both and you should get a new top-level Menu entry. Play with the values to change URL target and/or display name.
For the second option you can add a new top level Item – leaving the „Type“ field empty shoudl create a submenu, if you want to have more than one external URL linked. Hope this helps?!
kind regards,
-mike
