Schlagwörter: OAuth2
Ansicht von 5 Antwort-Threads
    • 5. Januar 2024 um 8:33 Uhr - Views: 1113 #29653
      marbert
        bei der Installation auf einem CentOS 8 Stream unter Otobo 10.0.19 bekomme ich folgende Fehlermeldung:
        $ otobo.Console.pl Admin::Package::Install MailAccount-OAuth2-10.0.2.opm
        Installing package...
        Notice: Install /opt/otobo/Custom/Kernel/Modules/AdminMailAccount.pm (660)!
        Notice: Install /opt/otobo/Custom/Kernel/Output/HTML/Templates/Standard/AdminMailAccount.tt (660)!
        Notice: Install /opt/otobo/Custom/Kernel/System/MailAccount.pm (660)!
        Notice: Install /opt/otobo/Custom/Kernel/System/MailAccount/POP3.pm (660)!
        Notice: Install /opt/otobo/Kernel/Config/Files/XML/MailAccountOAuth2.xml (660)!
        Notice: Install /opt/otobo/Kernel/Language/de_MailAccountOAuth2.pm (660)!
        Notice: Install /opt/otobo/Kernel/System/MailAccount/IMAPOAuth2.pm (660)!
        Notice: Install /opt/otobo/Kernel/System/MailAccount/POP3OAuth2.pm (660)!
        Notice: Install /opt/otobo/Kernel/System/OAuth2/MailAccount.pm (660)!
        Notice: Install /opt/otobo/Kernel/System/OAuth2.pm (660)!
        Notice: Install /opt/otobo/doc/en/Mailaccount-OAuth2.pdf (660)!
        Notice: Install /opt/otobo/var/httpd/htdocs/js/Core.Agent.Admin.MailAccount.js (660)!
        ERROR: OTOBO-otobo.Console.pl-Admin::Package::Install-20 Perl: 5.26.3 OS: linux Time: Thu Jan 4 19:42:35 2024
        Message: Unknown data type 'TEXT'!
        Traceback (8200):
        Module: Kernel::System::DB::_TypeCheck Line: 2025
        Module: Kernel::System::DB::SQLProcessor Line: 1180
        Module: Kernel::System::Package::_Database Line: 3610
        Module: Kernel::System::Package::PackageInstall Line: 642
        Module: Kernel::System::Console::Command::Admin::Package::Install::Run Line: 90
        Module: (eval) Line: 468
        Module: bin/otobo.Console.pl Line: 35
        Notice: ALTER TABLE mail_account ADD oauth2_profile VARCHAR (45) NULL
        Notice: UPDATE mail_account SET oauth2_profile = '0' WHERE oauth2_profile IS NULL
        Notice: ALTER TABLE mail_account CHANGE oauth2_profile oauth2_profile VARCHAR (45) DEFAULT '0' NULL
        Notice: CREATE TABLE auth_token (
        account_type VARCHAR (25) NOT NULL,
        account_id VARCHAR (150) NOT NULL,
        token_type VARCHAR (20) NOT NULL,
        token TEXT NOT NULL
        Done.
        Es gibt dazu im englischen Forum auch schon ein Topic, aber ich traue der Sache nicht so ganz, dass man diese Meldung ignorieren kann. https://otobo.io/en/forums/topic/unknow-type-text-installing-oauth2-on-otobo-10-0-16/
        Eventuell führt der Fehler dann ja dazu, dass folgende Aktionen nicht mehr ausgeführt werden. Weiß jemand wie man den Fehler verhindern kann?
      • 5. Januar 2024 um 9:01 Uhr #29829
          Hallo marbert,
          wir haben die OAuth2 Version 10.1.2 im Einsatz nutzen aber auch die Otobo 10.1.8
          Welche Version wird denn in der Paketverwaltung aktuell angeboten?
        • 5. Januar 2024 um 9:51 Uhr #29830
          marbert
            Da wir noch den 10.0er-Zweig verwenden, gehe ich davon aus, dass wir auch das 10.0er-AddOn installieren müssen, oder? Unser System hat keinen direkten Onlinezugang, deswegen lade ich das AddOn von der Webseite herunter und installiere es über die Kommandozeile.
          • 5. Januar 2024 um 10:07 Uhr #29831
              In der Moduldokumentation steht folgendes:
              This module was programmed for OTOBO 10.0.x.
              Sollte daher auch mit der 10.0.19 funktionieren.
            • 5. Januar 2024 um 13:14 Uhr #29834
              marbert
                Ich vermute da eher, dass das beim Wechsel auf 10.1 nicht angepasst wurde ;-)
                Ansonsten würde mich auch verwundern warum die 10.0er-Version nach der 10.1er-Version released wurde bzw. warum dann überhaupt:
                MailAccount-OAuth2-10.0.1.opm 03-May-2022 05:08 465K
                MailAccount-OAuth2-10.0.2.opm 19-Jul-2023 08:30 465K
                MailAccount-OAuth2-10.1.1.opm 03-May-2022 05:08 465K
                MailAccount-OAuth2-10.1.2.opm 11-Jul-2023 07:14 466K
                Aktuell kann ich aber leider nicht testen ob das einen Unterschied machen würde.
              • 30. Januar 2024 um 13:02 Uhr #29897
                marbert
                  Wenn ich anhand der Fehlermeldung in die Datei /opt/otobo/Kernel/System/DB.pm in Zeile in Zeile 2025 schaue, dann finde ich die Ursache in sub _TypeCheck:
                  if (
                  $Tag->{Type}
                  && $Tag->{Type} !~ /^(DATE|SMALLINT|BIGINT|INTEGER|DECIMAL|VARCHAR|LONGBLOB)$/i
                  ==> anscheinend ist der Datentyp „TEXT“ gar nicht erlaubt. Wundere mich nur warum dass dann nicht bei allen eine Fehlermeldung wirft, denn in den aktuellen Git-Quellen steht das so auch drinnen. Ausgewertet wird der Returnwert von TypeCheck nicht. Von daher kann man die Meldung wohl ignorieren.
