26. Februar 2025 um 14:53 Uhr - Views: 375 #34352
Hi there,
My name is Luis, I’m trying to create and integrate a custom module to authenticate customers thru an external API, but after several attempts I changed some settings and now I have an error when I tried to rebuild the config:
I removed all the config files (previously)
From the Admin Console I have incorrect settings but I don’t know how to remove them
These are my config files AuthAPI1.xml
<?xml version=“1.0″ encoding=“utf-8″?>
<otobo_config version=“2.0″ init=“Changes“>
<Setting Name=“Customer::AuthModule“ Required=“1″ Valid=“1″ ConfigLevel=“200″>
<Description Translatable=“1″>Defines the module to authenticate customers.</Description>
<Navigation>Core::Auth::Customer</Navigation>
<Value>
<Item ValueType=“PerlModule“ ValueFilter=“Kernel/System/CustomerAuth/*.pm“>Kernel::System::CustomerAuth::AuthAPI1</Item>
</Value>
</Setting>
</otobo_config>AuthAPI1.pm:
package Kernel::System::CustomerAuth::AuthAPI1;
use strict;
use warnings;
use LWP::UserAgent;
use JSON;sub new {
my ( $Type, %Param ) = @_;
my $Self = {};
bless( $Self, $Type );
return $Self;
}sub GetOption {
my ( $Self, %Param ) = @_;# check needed stuff
if ( !$Param{What} ) {
$Self->{LogObject}->Log( Priority => ‚error‘, Message => „Need What!“ );
return;
}# module options
my %Option = ( PreAuth => 0, );# return option
return $Option{ $Param{What} };
}sub Auth {
my ( $Self, %Param ) = @_;my $Username = $Param{User};
my $Password = $Param{Pw};return if !$Username || !$Password;
my $api_url = „https://MyLoginAPIfromMyDomain“;
my $ua = LWP::UserAgent->new;
my $response = $ua->post(
$api_url,
Content_Type => ‚application/json‘,
Content => encode_json( { cui => $Username, password => $Password } ),
);if ( $response->is_success ) {
my $decoded_response = decode_json( $response->decoded_content );
return $Username if $decoded_response->{authenticated};
}return;
}1;
I found this command, but I am not sure how to use it:
bin/otobo.Console.pl Admin::Config::Update –setting-name SMIME::CertPath –value ‚/opt/otobo/var/certs‘ –no-deploy¿How can effectively remove those incorrect settings in order to rebuild again the configuration? Otobo version 10.1
Thanks for your help,
Regards
