13. September 2022 um 10:22 Uhr - Views: 646 #13697
all of a sudden, <Realname> has been added to the queue names.
how to remove it?
13. September 2022 um 15:32 Uhr #13700
Can you clarify your issue with more explanation of the problem, add screenshots if possible
14. September 2022 um 14:37 Uhr #13719
14. September 2022 um 18:02 Uhr #13724
Hi Jakub,
could you check the setting CustomerPanelSelectionType in the SysConfig. If you want to see the queue names then „Queue“ should be selected there. You can also show the System Email Addresses in the customer interface. In that case, you can check the settings in „Email Addresses“ in the admin interface.
Best regards,
14. September 2022 um 18:07 Uhr #13725
Also the setting of CustomerPanelSelectionString in the SysConfig is relevant. The placeholders <Realname> and <Email> are only replaced when the CustomerPanelSelectionType is „Queue“.
15. September 2022 um 8:50 Uhr #13726
I have a „queue“ set up.
I can somehow complete the field to make it disappear <realname> ? -
15. September 2022 um 10:31 Uhr #13728
Hi Jakub,
I take it that your CustomerPanelSelectionType is „Queue“. So you can remove the „<Realname>“ from the setting CustomerPanelSelectionString.
Note that I said it the wrong way around. Correct is:
The placeholders <Realname> and <Email> are only replaced when the CustomerPanelSelectionType is not „Queue“.
Best regards,
19. September 2022 um 13:57 Uhr #13750
Thanks!
