18. Januar 2023 um 9:18 Uhr - Views: 1059 #14578
I have a running OTOBO server with MariaDB which I like to migrate to PostgreSQL.
The migration.pl does not include OTOBO as an acceptable RELEASE.
How do I transfer my OTOBO from MariaDB to PostgreSQL?
7. März 2023 um 14:47 Uhr #14831
Hi Pradeep,
can you please explain your steps, cause according to your post i getting the understanding that you directly
run the migration.pl have you done anything else before that?
Br,
Bq -
9. März 2023 um 5:11 Uhr #14844
Hi Br
I am unable to run the migration.pl as I am not running OTRS but OTOBO.
When I run migration.pl it complains about OTRS.
I am not sure if I can migrate OTOBO mysql to OTOBO postgresql.
9. März 2023 um 8:11 Uhr #14845
Hi Pradeep,
can you please post your error here maybe as a screenshot.
9. März 2023 um 13:00 Uhr #14855
Here it is:
13. März 2023 um 11:45 Uhr #14881
Check your current OTRS version and product: Verify the version and product of your current OTRS installation by checking the OTRS system information page or configuration files.
Verify the OTRS release file you are using: Make sure that the OTRS release file you are using matches the version and product of your current OTRS installation.
delete all the cache and –> bin/otrs.Console.pl Maint::Cache::Delete
disable the otobo’S securemode and run the migration again.
30. März 2023 um 7:37 Uhr #15002
I don’t run OTRS.
I wanted to convert OTOBO from MySQL to PostgreSQL.
