Schlagwörter: , ,
    • #14027
      Stefano Grespan
        I’m trying to implement Kerberos SSO authentication in our existing Otobo docker installation but, according to the guide, we should be using Https. By now, we have just HTTP (no Nginx container). Is there a way to add Https support to our server? Or we have to setup a brand-new installation?
        Thanks
      • #14093
        Stefano Grespan
          Solved: i’ve tried to implement HTTPS on my existing installation and it works. Just followed the installation guide point 4 (4. Set up a volume with SSL configuration for the nginx webproxy) and restarted docker-compose with a new .env file with certificates path. Everything ok
        • #14094
            Hi Stefano,
            thanks for the update. It is always nice to hear when things actually work.
            Best regards,
