    • 4. November 2026 um 22:42 Uhr - Views: 146 #45569
      Leon Baier
        I just wanted to upgrade Otobo to 11.1.1 and bin/otobo.CheckModules.pl --list says I need to install libdbd-mariadb-perl, but it’s not available for Ubuntu 24.04.
        I have libdbd-mysql-perl installed. Will this work with MariaDB 10.11.14?
      • 5. November 2026 um 8:17 Uhr #45574
          Hello Leon Baier,
          i think, you can run the following commands to ensure the universe repository is enabled and install the missing package:
          sudo add-apt-repository universe
          sudo apt update
          sudo apt install -y libdbd-mariadb-perl
          then verify:
          dpkg -l | grep libdbd-mariadb-perl
          Take a snapshot/backup prior to the upgrade.
          Or change your Otobo install to Docker.
          KR,
        • 5. November 2026 um 13:32 Uhr #45579
          Leon Baier
            Thanks for the reply. I already had universe enabled, but re-added it anyway. The package is still not available on Ubuntu 24.04.
            If I see it correctly, it is only available for riscv64, not amd64.
            https://packages.ubuntu.com/noble/libdbd-mariadb-perl
            Can I keep using libdbd-mysql-perl instead?
          • 6. November 2026 um 9:39 Uhr #45589
              Hello Leon,
              I read that this problem no longer exists under Ubuntu 26.04 LTS.
              Can you make an release upgrade and test with the new Version?
              sudo do-release-upgrade
              I cannot say whether there is an issue with libdbd-mysql-perl; we only use OTOBO on Docker.
