Schlagwörter: Docker Daemon
28. Februar 2023 um 18:14 Uhr - Views: 2615 #14775
I have been trying to do fresh install of otobo latest-10_1 with docker but the deamon_1 image doesn’t start correctly and stays unhealthy, last week i can’t remember the day i could do it, but now i am having troubles to start it in the end.
I have tried to install and deamon stays unhealthy, tried afterwards prune everything and start again and in the end unhealthy
Tried with fresh system installation of ubuntu 22.04 and unhealthy, even tried with a fresh installation of ubuntu 20.04 and same output.I don’t know but this seem to be something on your side, can you please check it?
Best,
Gf
1. März 2023 um 8:32 Uhr #14778
Hello Gf,
did you install the docker directly in the Ubuntu Setup or after the this with the following commands?
—- Install Docker —
sudo apt-get install git docker docker-compose curl
sudo systemctl enable dockerKR,
1. März 2023 um 10:48 Uhr #14781
I did follow this installation guide where that step is prerequisite of the installation, if didn’t do that step i practically couldn’t do anything else.
Best,
Gf
1. März 2023 um 11:13 Uhr #14782
the following docu works for me -> only http testet
— Install Ubuntu Server VM —> Ubuntu Server 20.04.5
[X] use new Ubuntu installer
[X] install open SSH Server
sudo apt update
sudo apt upgradesudo apt install net-tools
— Set Timezone —
timedatectl list-timezones
sudo timedatectl set-timezone Europe/Berlin ->set your time zone, i use Europe/Berlin
check with „date“ or „timedatectl“—- Install Docker —
sudo systemctl enable dockersudo apt update
sudo apt upgrade— otobo install —
cd /optsudo git clone https://github.com/RotherOSS/otobo-docker.git –branch rel-10_1 –single-branch
ls otobo-docker # just a sanity check, README.md should exist
cd /opt/otobo-docker
sudo cp -p .docker_compose_env_http .env
sudo nano .env (file edit -> OTOBO_DB_ROOT_PASSWORD=<your_secret_password>) -> press ctrl + x = close file / press y = save file
sudo docker-compose up –detach
sudo docker-compose ps
sudo docker volume lsRun the OTOBO installer at http://yourIPorFQDN/otobo/installer.pl
1. März 2023 um 11:28 Uhr #14784
I am using https but i will try again with slight differences you are suggesting, i’ll let you know how it goes.
1. März 2023 um 16:12 Uhr #14793
Well Marcel,
I didn’t work for me, i have tried with a snapshot of a VM in the moment it was configured with network and hostnames and so on, did run then your script and otobo_daemon_1 still unhealthy
To discard the virtualization environment i did install it on a different virtualization platform with a fresh installed ubuntu on the version 20.04, again with your script and otobo_daemon_1 still unhealthy.
I know it works on this virtualization platform because i have a otobo working there, it was installed on version 10_0 though and upgraded to 10_1
To discard 2 otobos working on the same network i did shutdown the production one and tried to start the fresh installed alone and still otobo_daemon_1 unhealthy
My next step is install otobo with docker but on version 10_0 and then upgrade it, do you know if there is a guide on how to install an older version?
Thank you,
Gf
1. März 2023 um 20:44 Uhr #14794
Hi Gonçalo,
If I understand correctly the container otobo_daemon_1 is running but is reported as unhealthy. The health check for the daemon contain is defined in the file docker-compose/otobo-base.yml . It is defined as
./bin/otobo.Daemon.pl status | grep 'Daemon running'. You could log into the running container withdocker-compose exec daemon bashand check what./bin/otobo.Daemon.pl statusprints to STDOUT and STDERR.Best regards,
2. März 2023 um 11:49 Uhr #14802
Hi Bernhard,
The status said it was not started, so i started it and this is the output
otobo@256b18f860f5:~$ ./bin/otobo.Daemon.pl start
Manage the OTOBO daemon process.
Daemon started
Stopping the OTOBO Daemon as SecureMode is not activated.Thank you,
Best,
Gf
2. März 2023 um 7:55 Uhr #14796
Hello Gf,
you must clone the older repo „rel-10_0“
https://doc.otobo.de/manual/installation/10.0/en/content/installation-docker.html
sudo git clone https://github.com/RotherOSS/otobo-docker.git –branch rel-10_0 –single-branch
2. März 2023 um 11:49 Uhr #14803
Thank you Marcel,
will try it.
Best,
Gf
2. März 2023 um 12:21 Uhr #14804
Hi Gonçalo,
the SecureMode is a safety guard to prevent conflicts when OTOBO is being installed or maintained. SecureMode = 1 indicates that it is safe to continue with normal operation Therefore it is normal that the Daemon refuses to start when OTOBO hasn’t been completely installed yet. Thus the unhealthy status does not indicate that there is a problem, just that the Daemon is currently not running. There is also an automatic start of the Daemon once the SecureMode has been activated.
So I propose that you continue with installation and wait two minutes after installation has been completed. For idetails see the file /opt/otobo_install/entrypoint.sh in the web or daemon container.
Best regards,
Bernhard Schmalhofer
2. März 2023 um 12:45 Uhr #14805
Hi again Bernhard,
I got it right now, i was just entering on the web page this http://yourIPorFQDN/otobo/ instead of this http://yourIPorFQDN/otobo/installer.pl and my sys admin knowledge started to look for the problem and found the unhealthy deamon so i thought it was the problem.
Thank you very much,
Gf
