Schlagwörter: redirect
4. März 2022 um 15:05 Uhr - Views: 1375 #12750
Hello friends, after migrating to version 10.1, customers when accessing https://mysub.mydomain.com/otobo/customer.pl are redirected to https://mysub.mydomain.com/otobo/index.pl what can i do to fix ?
Thanks
4. März 2022 um 16:20 Uhr #12751
Hello Korost,
in OTOBO 10.1 there are a couple of new OTOBO SysConfig settings that control the behaviour. In your case I can imagine that the customer interface is deactivated and that the agent interface is configured as the default. Could you check your setup. In my test installation it looks like this:
bes:~/devel/OTOBO/otobo (rel-10_1)$ bin/otobo.Console.pl Admin::Config::Read --setting-name CustomerFrontend::Active
Gathering setting value...Setting: CustomerFrontend::Active
1Done.
bes:~/devel/OTOBO/otobo (rel-10_1)$ bin/otobo.Console.pl Admin::Config::Read --setting-name Frontend::DefaultInterface
Gathering setting value...Setting: Frontend::DefaultInterface
index.plDone.
bes:~/devel/OTOBO/otobo (rel-10_1)$If the customer frontend is deactivated you could activate it via the SysConfig in the Web-GUI or with the command:
bin/otobo.Console.pl Admin::Config::Update –setting-name CustomerFrontend::Active –value 1
Best regards,
4. März 2022 um 17:43 Uhr #12752
Thanks, it worked!
6. März 2022 um 11:33 Uhr #12759
In order to avoid this effect the updating instructions have been updated in https://doc.otobo.org/manual/installation/10.1/de/content/updating.html . Step 4 now includes the command
/opt/otobo/bin/otobo.Console.pl Maint::Config::Rebuildwhich should make the upgrading procedure smoother.
