Schlagwörter: SSL
    • 21. Juli 2021 um 16:56 Uhr - Views: 1855 #11767
        Good Evening,
        I have tryed to install otobo with docker and ssl certificate.
        I have a problem with ssl certificate.
        I have read manual, point 4, but when the installation ends, I can’t able to connect http://youriporfqdn/otobo/installer.pl.
        I have copied and set the two files (.crt and .key) in this directory /etc/nginx/ssl/.
        If I install otobo with self signed certificates, I haven’t problem.
        I have used this configuration file .docker_compose_env_https (default file).
        I have opened on firewall only 22,80,443 ports.
        Thank you for support
      • 29. Juli 2021 um 14:55 Uhr #11779
          Good Morning,
          where can I set FQDN in nginx configuration file docker installation?
          Because I have installed and set ssl certificate path in .env file but if I connect with IP it’s OK with FQDN I  can’t connect it.
          For Example: https://IPSERVER/otobo/index.pl    –> OK  –> I used this .docker_compose_env_https and I have set only ssl path and DB password
          https://FQDN/otobo/index. pl –> Error
          Thank You
      • Das Thema „ SSL Certicate“ ist für neue Antworten geschlossen.
