Schlagwörter: login slow HTTP HTTPS
    • 21. Oktober 2024 um 15:06 Uhr - Views: 475 #32492
      AnteIde Marić
        After I successfully migrated to OTOBO 10.1, I noticed that the login was very slow. It takes about 6 seconds. I tested that it depends on the „Settings“ on the right, that is, how many widgets will be displayed on the home page. If I reduce the number of widgets, it speeds up tremendously. I have no problem with this on the OTRS 6 community edition, and it works much faster, but I don’t use HTTPS there, so maybe that’s the problem. Does anyone know how to fix this? If I stop „nginx“ container OTOBO won’t work either on the HTTP. Does anyone know how to easily turn off HTTPS on an existing docker OTOBO installation?
        Thank you
      • 21. Oktober 2024 um 16:33 Uhr #32499
        AnteIde Marić
          this is a duplicate of this one https://otobo.io/forums/topic/very-slow-login-2/ so I’m closing the ticket
      • Das Thema „ Very slow login“ ist für neue Antworten geschlossen.
