Ansicht von 1 Antwort-Thread
Schlagwörter: CMDB
Hi all. I use cmdb in otobo and have a problem.
How I can filter hardware by owner (add columns or search template)?
Hello Alexander, in order to search on an specific field, you need to make that field searchable in your class definition.
Example
– Input:
Class: ITSM::ConfigItem::Computer::Type
Translation: 1
Type: GeneralCatalog
Key: Type
Searchable: 1
Hope it helps to solve your question
